07-30-2018
19:12
08:07
HeydyF
07-30-2018
19:12
08:07
HeydyF
Two issues. Versa App is not working for weather and not working for sleep. Read manual...still not working
07-31-2018 08:16
07-31-2018 08:16
Hey @Sherry1225, it is great to see new members around! I'd like you to be a little bit more specific about the issues that you have with the weather app and the sleep. When you say that the weather isn't working, are you saying that your current location isn't updating? If so, check that you turned on location services for the Fitbit app. For instructions, see How do I allow the Fitbit app to use my phone's GPS? If you change locations, sync your watch to see your new location in the Weather app.
To change the units used for the temperature in the Weather app:
Now in regards of your sleep, are you not getting sleep stages or you are not even getting sleep stages?
I'll be around so keep me posted!
07-31-2018 09:51
07-31-2018 09:51
07-31-2018 11:32
07-31-2018 11:32
Hey @Sherry1225, thanks for your reply! If you have made sure that the location services are on for the Fitbit app, you synced and still not showing the weather, try to restart your Versa by following these instructions:
Then sync your Versa again and it should show the correct weather.
Keep me posted!
08-07-2018 15:27
08-07-2018 15:27
It worked for a day. Not working again. Says I have to sync again..I do...turned it off...still not working
