Weather app is in celcious Versa
since nee update my weather is in celcious. How to I change it?
Moderator edit: format
1 REPLY 1
Hi, go within the Fitbit app to Apps and press it. You'll see My apps and listed there is the Weather app. On the right side next to it's name there is a settings icon, press that and you are able to change the temperature unit from Celsius to Farhenheit. Good luck!
