01-18-2022
12:53
20:34
01-18-2022
12:53
20:34
How can I change cities on weather app for versa 3. It shows correct city name. But is not my city it's reading another city across the USA with the same name.
01-18-2022 13:05
01-18-2022 13:05
On the phone app tap on your profile photo (top left corner) to bring you to the settings page. Scroll down and tap on the Versa3 tile. Then tap the Gallery tile. Scroll down to find the Weather app tile and tap that. Tap the Settings tile.There should be an edit link to remove the wrong city and then an Add City link to add your correct city.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
01-18-2022 16:06
01-18-2022 16:06
Thank you so much. Great instructions! All is good now 👍
01-18-2022 16:10
01-18-2022 16:10
