Weather isn't showing the temperature. It just has location and C. i have it set up to show current location (which is correct) and temperature in Farenheit. this has been like this since i updated.
any help would be appreciated!
Best AnswerHi, if you want to change the temperature unit to Celsius, do the following:
1.On your dashboard of the Fitbit App, press the watch icon on top of the screen on the right side.
2. This will bring you to the page with the Clock Faces and Apps tiles.
3. Press the Apps tile and you will see "My Apps" and "All Apps"
4. Go to "my apps"and scroll down untill you find the weather app.
5. There should be a settings icon right next to the name of the app.
6. Press the settings icon and you will see a page showing Temperature Unit.
7. Press Unit directly underneath that and you can change the temperature unit in whatever you want.
Best AnswerI have followed this instructions multiple times without success. All I get is my city name and --C. The City is always the same and the temperature does not register. I get a message Accuweather... sync the Fitbit mobile app to update.
Would really like this to function as designed!
