12-07-2018 21:58
12-07-2018 21:58
My Versa mobile app is syncing, but my weather information is not working. It lists my current location, but no temperatures, etc...
12-08-2018 14:39
12-08-2018 14:39
Hi, might not be a Versa problem but one of AccuWeather, which sometimes happens. Had that too. If your weather does not sync within a few hours, go to the Fitbit app, press the Versa icon (screen above right) and go to apps. Choose the Fitbit apps and got to weather and press the settings at the right side of the screen. If there is only your current location, choose add location and enter the exact location where you live. In most of the times this will solve the problem, at least it did for me.
12-09-2018
07:05
07:44
12-09-2018
07:05
07:44
It's great to see you here @SBess and @SunsetRunner thanks for the input.
I appreciate all the efforts in trying to fix this issue and would like to know if the instructions provided by our friend worked? Is your weather updated now?
Hope to hear from you soon.
12-10-2018 06:12
12-10-2018 06:12
12-12-2018
03:53
07:44
12-12-2018
03:53
07:44
Those are great news @SBess, I am glad to hear that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
05-18-2019 13:20
05-18-2019 13:20
after following your instructions, the temperature on my watch still is at 66 degrees. It's at least 90 here at this moment. Any other suggestions?
05-18-2019 13:22
05-18-2019 13:22
Well, disregard. Evidently it took it a few minutes. It now says it's 90 degrees.
Thanks for your help
08-11-2019 17:26 - edited 08-11-2019 17:29
I was having the same problem and putting in my city, instead of current location, worked. Thanks!
