07-05-2018
10:36
10:03
HeydyF
07-05-2018
10:36
10:03
HeydyF
I purchased a Versa a few weeks ago and I was able to get it to sync with my iPhone. The last sync was on June 30 and since then it has failed to sync. I read the topics and noted this seems to be an issue with many others. I entered a chat with Juan at Fitbit yesterday and I thought we had it fixed; however, I noticed the heart rate information does not show up on the iPhone and I still can't get can't get weather on the Versa. Juan suggested several things but it still isn't working.
07-06-2018 10:02
07-06-2018 10:02
Hey @gustav1938, let me give you a warm welcome to the Community! I appreciate the time you have taken to get in touch with our Support team for further help. Now, if you have inconveniences, I'll be glad to give you a hand on this. In regards of the Weather, I'd like you to take the following into consideration:
Now in regards of your heart rate not showing up on the Fitbit app, please make sure Bluetooth is enabled on your mobile device. In the Fitbit apps for iOS and Windows 10, also make sure all-day sync is turned on.
Let me know how it goes!
Best Answer07-13-2018 13:35
07-13-2018 13:35
My Versa is bsynching the heart rate and I can Chet the weather. Thanks for the help. My Versa doesn’t seem to give me credit for sleep
Best Answer07-14-2018 05:00
07-14-2018 05:00
Thanks for getting back to me @gustav1938! Sounds pretty good that your heart rate it's being tracked correctly and the weather as well. If your Versa doesn't seem to be tracking your sleep, I suggest you to take into consideration the following:
Best Answer07-15-2018 19:09
07-15-2018 19:09
Best Answer07-16-2018 05:56
07-16-2018 05:56
Thanks for the update @gustav1938! Sounds pretty great that you can now enjoy the manually logging feature. You'll see that is pretty useful.
If you have further questions or comments, let me know!
