10-24-2022 00:58
10-24-2022 00:58
Hi is it possible to change the weight to kilos instead of pounds? If so, can anyone help me? Thanks
10-24-2022 04:55
10-24-2022 04:55
Hi @Ronce Yes there is away to change it. Go to the website Dashboard (at the top of this page select dashboard), then select the gear icon in the top right corner and select Settings from the drop down menu. Then scroll down to Units and you can change to metric there
Helen | Western Australia
