04-25-2018 10:58
04-25-2018 10:58
I have some wireless headphones that connect via Bluetooth but for some reason the Versa isn't picking them up, does anyone know anyone know if i need fitbit headphones or a certain type? Thank you.
08-12-2018 16:07
08-12-2018 16:07
How are your earphones holding up?
08-12-2018 16:14
08-12-2018 16:14
08-12-2018 17:47
08-12-2018 17:47
08-12-2018 19:21
08-12-2018 19:28
08-17-2018 15:23
08-17-2018 15:23
Will the SENSO Bluetooth Headphones work with the Fitbit Versa?
08-17-2018 15:25
08-17-2018 15:25
08-17-2018 15:25
08-17-2018 15:25
09-09-2018 12:59
09-09-2018 12:59
I've worked out what is going on after a bit of playing around!, this may solve your issues too hopefully! ...... Mine wasn't pairing, it could see it but wouldn't pair, so i thought maybe its because the headphones are connected to my phone and laptop and 3 devices is to many. I disconnected my phone from the speakers, and the watch then connected. There was loads of static and cutting in and out though so thought maybe its because its connected to the laptop, so I disconnected it from the laptop and that fixed it. So just disconnect the speakers from any other devices and they should connect and work a treat!!
09-09-2018 13:01
09-09-2018 13:01
disconnect it from any other devices its connected to, that worked for me.
09-09-2018 13:12
09-09-2018 13:12
09-09-2018 17:23
09-09-2018 17:23
10-03-2018 13:18
10-03-2018 13:18
Super helpful! Thank you
12-02-2018 08:31
12-02-2018 08:31
Thank you so much for your suggestion. I too was having a hard time pairing my earbuds to my Versa. You were a great help 😁
12-26-2018 16:10
12-26-2018 16:10
Can I you use apple ear pods for this watch
12-26-2018 16:54
12-26-2018 16:54
12-27-2018 12:40
12-27-2018 12:40
This definitely helped! Thanks! I have the Skullcandy wireless headphones.
12-27-2018 15:36
12-27-2018 15:36
12-29-2018 11:49
12-29-2018 11:49
The best ones that work on Versa bar none, are the Plantronics, any type, which are the Sport and the Wireless earbuds. The Versa doesnt work at all with Jabra 65T nor Sony NMX, but the plantronics not a problem.
01-01-2019 15:27
01-01-2019 15:27
My new BT 4.0 headphones would not connect to Versa, and it was pointed out to me that your headphones need BT 5.0.
