04-25-2018 10:58
04-25-2018 10:58
I have some wireless headphones that connect via Bluetooth but for some reason the Versa isn't picking them up, does anyone know anyone know if i need fitbit headphones or a certain type? Thank you.
01-11-2019 19:43
01-11-2019 19:43
I have those headphones and dk how to pair them
01-11-2019 20:03
01-11-2019 20:03
You really weren’t any help Sasha but another user in the community gave me the answer I was looking for...thank you to the Fitbit community.
01-12-2019 15:11
01-12-2019 15:11
Hi there. Do you think the Ink’d 2 would work with the versa?
01-12-2019 15:39
01-12-2019 15:55 - last edited on 10-02-2019 13:57 by LiliyaFitbit
I saw that after I submitted the questions. Thanks for the quick response.
01-12-2019 18:55
01-12-2019 18:55
01-12-2019 21:03
01-12-2019 21:03
Jaybird X3 .. hold middle button on X3 till discovery is announced. Then ask Versa to connect to device. Connected without issue.
¡BBB!
01-15-2019 01:14
01-15-2019 01:14
I had bad static when playing music from Versa to Bluetooth headphones. I found my new (2019!!) headphones used Bluetooth v3.0 whilst the Versa uses v4.0. I bought a cheap pair of new Bluetooth earbuds which used v4.1 for $30 (XCD brand in Australia) and these worked perfectly. I know the Versa should technically be backward compatible but maybe it’s not. For me, the earbuds with Bluetooth v4.1 worked - static totally gone.
01-15-2019 17:54
01-15-2019 17:54
I had the same problem with the music from the Bluetooth earbuds sounding choppy, staticky and awful-I almost took the Versa back but I am glad I read this post first. I went and bought the $19.99 “Heyday” earbuds from target-music sounds perfect! I am soooo relieved!!!
01-19-2019 16:43
01-19-2019 16:43
I purchased the skullcandy ink’d wirless and LOVE them. The completely fixed the problem. Thank you to this community for helping me fix the static and skipping of my headphones. I can work out and keep my music going. Thank you thank you!!!
01-19-2019 19:49
01-19-2019 19:49
01-26-2019 03:58
01-26-2019 03:58
Doesn’t work at all with my aftershokz trekz titanium headphone. It detects it but pairing doesn’t happen. Left both close together for a few hours, but still won’t pair. I just gave up. It sucks.
01-26-2019 05:04
01-26-2019 05:04
01-27-2019 14:25
01-27-2019 14:25
Also try iWorld earbuds work great for mine. Tried Onn and played horrible but they work Ok with my Phone. But the IWorld sound the best I have heard.
02-22-2019 22:29
02-22-2019 22:29
The Audiofly AF22W In-Ear Wireless Bluetooth Headphones (Black) do NOT play music properly when paired to the Versa. They pair, but music is scratchy and drops out all the time. Purchased in Australia for $50.
03-06-2019 17:44
03-06-2019 17:44
I shutdown my Galaxy S8 after connecting and pairing, shutdown Versa and reset my Trekz Titanium headphones (follow instructions in owner pamphlet). The only thing I did differently this time while following the directions in your link was while my headphones where pairing (red and blue lights flashing) I immediately hit add audio device under bluethooth connections on versa. I'm playing my music.
04-19-2019 07:46
04-19-2019 07:46
Hi!
I am trying to pair my scull candy headphones to my versa and it pairs but the sound doesn't work. I know the headphones work because I use them on my cell and it works fine. Can I get some help?
Thank you!
04-21-2019 15:38
04-21-2019 15:38
You need to follow the instructions for pairing. You will also need to tell it every time you use the music on your versa. You have to pick the bluetooth headphones to pair them again.
05-14-2019 09:23
05-14-2019 09:23
I have a Fitbit versa I bought dollar store wireless headphones brand is billboard will these connect to versa or do I need a particular kind of headphone I've restarted both it just keeps saying device not found , I tried Bluetooth headphones to my Android and they connect no problem , so question is do I need to get the flyer headphones or what headphones not exspensie will work ?Please and thank you help
05-14-2019 11:49
05-14-2019 11:49
