07-22-2018 12:46
07-22-2018 12:46
Hi, I have Betron BR-74 earphones, specifically bought these for my new Versa, however when I try to pair them my watch doesn’t find it. Is there a list of what brand earphones work with Versa? I find it ridiculous that you have to try your luck, instead of actually knowing...
Has anyone successfully conected Bbetting to Versa before?
07-23-2018 02:35
07-23-2018 02:35
Hi Guys,
An update for you. Of course there is always something wrong with a process rather than devices.
I have successfully paired my watch with earphones. The issue was that my earphones kept automatically connecting to my phone, which I wasn't aware of. Once I disconnected it from my phone, I was able to pair it with my watch.
Thanks everyone for your support.
Sigita
07-22-2018 13:02
07-22-2018 13:02
I just successfully paired my Versa with these:
Sony SP600N Wireless Noise Canceling Sports In-Ear Headphones, White (WI-SP600N/W)
The only hard part was finding the Setting icon on the Versa (swipe right a couple of times from the Apps screen.) The other trick was to put the headphones in pairing mode (by holding down the power button for 10 seconds) before choosing the Bluetooth setting to pair a device.
07-22-2018 13:11
07-22-2018 13:11
Thanks Straz, I’m doing everything correctly. I am probably unlucky with my earphones brand being incompatible with my watch...
07-22-2018 19:46
07-22-2018 19:46
Hello @Syga,
I successfully connected my Ionic with a couple of supercheap Chinese made earphones without any single problem (apart my trusty Flyers and Bose QuietConfort) so it looks really strange.
Did your try to connect your earphones to your smartphone to see if they are the culprit?
07-23-2018 01:52
07-23-2018 01:52
Hi Giampi,
Yes, it is strange. The earphones work with my Iphone, and the watch seems to find other audio devices (like tv etc), but my earphones.
I'll try to google more, see if I can do anything else, otherwise, I'll just have to return the earphones.
Thanks
07-23-2018 02:35
07-23-2018 02:35
Hi Guys,
Sigita
07-23-2018 03:47
07-23-2018 03:47
Thanks for the update. I accidentally did the same last night. My Versa couldn't pair with my headphones because they were instead pairing with my cell phone.
07-23-2018 06:29
07-23-2018 06:29
Excellent news guys!
I want to highlight that the Fitbit Flyers can keep two connections at the same time.
11-12-2018 11:46
11-12-2018 11:46
holding down the power button for 10 seconds works perfectly to connect BT device with Versa.
12-10-2018 17:42
12-10-2018 17:42
Thanks so much you helped me Pair my watch and the headphones I bought thinking it was broken and not compatible. Sad that the Instructions are not clear in the user manual.
09-06-2019 08:22
09-06-2019 08:22
thank you vikas!! your advice was helpful!! ❤️
11-25-2019 06:47
11-25-2019 06:47
I could give you a HUG right now!!! thank you so much for this. I was getting pretty stressed as I couldn't pair my versa to this new pair of sony mdr zx330bt. Was about to return the headphones back !! THANK YOU SO SO MUCH. XX
04-30-2020 09:26
04-30-2020 09:26
Syga, You are a genius! I thought I had wasted my money on earphones, but you saved me!
05-01-2020 14:02
05-01-2020 14:02
I wish the fix was as simple for me. I've been trying for days now and still doesn't pair.
09-03-2022 19:02
09-03-2022 19:02
Thank you, I will look into these.
