08-07-2020 16:50
08-07-2020 16:50
I would like to know for the thousands of customers that you guys have and there Fitbit devices won't work with there phones but you guys put that no where on the packing saying may not work with all devices/phones instead when I ask about it they say there is nothing they can do. I was literally told maybe use a device that works. Jayvee: You can try using a supported phone if you have one.
Hmm if you think I had one wouldn't I be freaking using it. I see alot of complaints being the same about devices not working. So yes Fitbit what in the heck r u going to do for your it paying cusomters that you give no warning to that your device might not work with it. And no checking the internet is not what you are suppose to do b fore you guy a Fitbit device.
Best Answer08-07-2020 16:53
08-07-2020 16:53
They told me today to use a supported phone... Well dumbasses maybe you should let your customers know on the box or some **ahem** that not all devices work ect.
Best Answer08-07-2020 17:08
08-07-2020 17:08
Hi @Hustleboi509 did you check out the system requirements before getting your Versa? Even with apps, you need a phone that's compatible. And yes, most people really do check requirements before purchasing a new device, even when it's a computer, tablet, fitness tracker, etc. You might want to tone down the profanity, as this is a public forum. Be upset, but remember you agreed to the Terms of Service when signing up to post here. Family friendly place and often younger ones visit.
08-07-2020 20:10 - edited 08-07-2020 20:14
My 4th or 5th FITBIT just died. They have a life expectancy of about 12 to 15 months. 2 have been replaced by Fitbit. The others were gifts past their warranty. While they worked they are great. Once they start going they are gone. My latest issue. I was waking up and my watch was not keeping time. It would reset when I checked my Fitbit app on the phone. The all of sudden it just did not keep up. I did all the button things. Turned off phone restarted WIFI & blue tooth The app on the phone was telling me it could not find the wifi. All the other devices were doing fine. I finally decided on a factory reset and the it never reset just went blank. Looking at Garmin for my next fitness tracker. I have had the following Fitbits, the Surge, Blaze & Versa.
08-07-2020 20:21
08-07-2020 20:21
08-07-2020 20:21
08-07-2020 20:21
Same here Versa stopped working about a week ago and now it is useless! Think I am going with an iWatch and wish $200 wasn’t wasted on a Fitbit.
08-08-2020 07:28 - edited 08-08-2020 07:29
A link to the phone requirements will be found on the outside of the package.
As everyone knows, the smaller the print, the more important the print is.
If you are asking and wanting to know what will fitbit do.
Please ask Fitbit and not the community of Fitbit users.
Asking the users to tell you what Fitbit will do is not going to get a usable answer and only cause frustration.
08-08-2020 13:23
08-08-2020 13:23
Best Answer08-08-2020 13:26
08-08-2020 13:26
Is it under warranty? If so then take it back to the retailer and get a refund.
Best Answer08-08-2020 14:49
08-08-2020 14:49
Best Answer08-08-2020 16:46
08-08-2020 16:46
08-08-2020 21:23
08-08-2020 21:23
This is about what happened to me, it would no longer turn on it wouldn't do nada dang thing..
Best Answer08-09-2020 02:31
08-09-2020 02:31
