01-10-2022 22:26
01-10-2022 22:26
Is there a range to keep the charge within that helps maximize longevity. Assuming Li-Po batteries like the Versa 2 has are similar to Li-Ion ones usually found on smartphones, would keeping it between 50-65% (while incredibly tedious) be a good baseline to maximize the battery lifespan. Of course, I could lean on a more reasonable range from that, like 30-85%
01-11-2022 05:09
01-11-2022 05:09
Hi @SunsetRunner - as you are interested, here is a post on the matter. How best to get the maximum longevity from the watch battery?
01-11-2022 23:59
01-11-2022 23:59
Thank you guy! I actually saw your comment after some deep searching before i posted my question. Do we know if Fitbit answered your question in regards to "For cars keeping the battery within the 25%-80% charge state is often recommended, However with circuitry this may already be the visible 0-100% portion. Only Fitbit can answer what is the real amount available to users."?
I was surprised (and bummed) when I saw your post didn't have much discussion as battery longevity is a big thing.
Personally i plan on keeping it between 20 and 80% with showers as my charge time (probably charge it every few days).
01-12-2022 00:00
01-12-2022 00:00
Can't seem to edit so tagging you here @Guy_
01-12-2022
00:35
05:06
01-12-2022
00:35
05:06
Hi @SunsetRunner - thanks for your feedback and interest, the issue is probably not many people come to the forum from all the owners, and few have interest in how long the battery lasts or the post is not easily findable, but...
From measurements,
The number of cycles is an important factor. I've done 118 charges in 470 days. The battery still should be good for 6.5 years.
Heavy loads, such as GPS may not be very pleasing for the battery if done often.
01-12-2022 02:30
01-12-2022 02:30
@SunsetRunner - if you have any comments perhaps posts them in the main discussion, it will make it more visible and others might join in.
