WhatsApp not displaying
Hi there, i just got Versa, i have an iPhone.
i dont receive notifications for WhatsApp, Facebook and Instagram.
i only receive calls, SMS, notifications from CNN, Bloomberg and 365 scores.
is there any solution to let the social media platforms being displayed?
8 REPLIES 8
Hi, try the following:
1. Go to notifications
2. Go to text messages and press this and you will get a list of apps that can send notifications to your Versa. Choose Whatsapp, it should be in the list, see: https://community.fitbit.com/t5/image/serverpage/image-id/85941i1EF6869578A4E5FE/image-size/medium?v... . This image is a screenshot of my Android device.
3. Restart your device and it should be possible to receive Whatsapp messages.
4. If you do not want to give up the text messages, leave it as it was and scroll down to:
5. App notifications, press this and you will get a list of all apps that can send notifications. Scroll down untill you find Whatsapp and choose it as the app.
Mind you though that , by differences in behaviour of Whatsapp on Android or iOS, you'll have to be online on your mobile device all the time if you want te receive messages on your Versa. Hope this helps, good luck.
Deleted, error message while posting.
It worked!
thaaaaaaaaaanks
Hi again 🙂
sorry for disturbing another time.
today, not all the notifications are being displayed, sometimes Instagram and not Whatsapp, ...
in the beginning of the day that happened, i restarted my iPhone and all worked. Now same issue happens again, Whatsapp, FB messenger and Instagram were not showing, so i restarted both iPhone and Versa, Whatsapp and FB messenger are displayed, Instagram is not!! 😑😑
is there anything I am doing wrong?!!
please I need a crucial solution, thanks.
Hi, unfortunately there is a problem between notifications and iPhones. In principle, Fitbit support fully Android notifications and are working very hard to do the same for the iPhone. I'm afraid that you will encounter these problems from time to time untill Fitbit has solved this issue, sorry!
Its not fitbit but Iphone that does not support it
See this thread that explains why by @AlessFitbit
https://community.fitbit.com/t5/Versa/Iphone-Users-using-quot-Quick-Replies-quot-to-Texts/m-p/259562...
Community Council Member
Wendy | CA | Moto G6 Android
This is not really bad. Fitbit should announce that it's not compatible with Apple products, since it is not functioning as it should!!!!!!!!
