03-14-2018
15:20
04:26
JuanJoFitbit
03-14-2018
15:20
04:26
JuanJoFitbit
Do you know if Fitbit Versa will be able to show whatsapp or fb messages notifications for Iphone users? I read in previous comments about it saying that it only works for Android but what about IOS?
Moderator edit: updated label
12-28-2019 13:06
12-28-2019 13:06
Are you in the notifications bit?
12-28-2019 13:09
12-28-2019 13:09
If you are in this tap on the apps and notifications and there should be a list what you have on your phone then tap the apps you want to notify you, if this then doesn’t work I would call Fitbit, sorry I can’t help more.
12-28-2019 15:31
12-28-2019 15:31
Yes I am and WhatsApp doesn’t come up as an option at all
12-30-2019 04:34 - last edited on 09-27-2020 13:50 by LiliyaFitbit
Yes
Kind Regards
12-30-2019 07:46
12-30-2019 07:46
Was this response intended for here? I’m confused as I’m still not getting messages/WhatsApp or calls coming through on my versa Fitbit
01-02-2020 11:46
01-02-2020 11:46
I am getting notifications on my iPhone but I am not able to read the message on my versa 2. Should I be able to read them on the versa 2? I have set up as suggested
01-04-2020 12:43
01-04-2020 12:43
My.fitbit lite is not sending what's ap mags and not fb .just calls and texts ..
01-05-2020 14:41
01-05-2020 14:41
Fitbit what's app call and message doesn't work on Android phone. One reason to purchase Fitbit was to get calls and notification from phone as well as WhatsApp. Very disappointed! What's the reason it doesn't work for Android. I have OnePlus 5T phone.
01-06-2020 01:16
01-06-2020 01:16
Hi everyone, I did the update yesterday on my iphone7 which is 13.3 then I updated the Fitbit versa 2 which I was a bit unsure about doing as a lot of people have had issues, long story short after update everything was still there on the watch which includes fb, WhatsApp & so on. I’m sorry I can’t help anymore on the issues you are having only that the suggestions I have already said & to make sure your phone has the recent update on them.
01-21-2020 12:30
01-21-2020 12:30
"Apps are added to this list after they have sent notifications to your phone already"
how do i do this for whatsapp?
02-13-2020 17:17
02-13-2020 17:17
My Versa2 doesn't have What's App or Facebook as options to select under Notifications - what do I do now?
03-03-2020 06:23
03-03-2020 06:23
Does anyone know how long it takes before the Whatsapp toggle functionality is available?
Other apps are available but not Whatsapp.
thanks
03-19-2020 13:04
03-19-2020 13:04
I have the same. So annoying, I tried literally everything. Anyone have an answer?
03-26-2020 05:39
03-26-2020 05:39
what do you mean by
i have iphone and can’t get it to notify me whatsapp
03-26-2020 05:41
03-26-2020 05:41
what happens if whatsapp isn’t listed??
03-26-2020 05:42
03-26-2020 05:42
did you solve this? I too bought one and so far i can’t always get it turned on and whatsapp doesn’t notify ?? iphone?
blaze was always fine
03-26-2020 07:29
03-26-2020 07:29
I had exactly the same problem on my iphone!
In your iphone notifications settings:
03-26-2020 08:59
03-26-2020 08:59
05-05-2020 00:29
05-05-2020 00:29
WhatsApp doesn't come up as an option even after notifications have been sent to my phone many times.
05-05-2020 01:27
05-05-2020 01:27
