When are going to fix the GPS connectivity issue with versa... FITBIT guys
I used fitbit charge2 and upgraded to versa. But its not connecting to GPS ....Either you are using cheap hardware or your software sucks ...
3 REPLIES 3
GPS tracking definitely is a problem. I bought it for mapping my bike routes but GPS is unreliable. It'll connect, then disconnect, then connect again, and so on. I ride a consistent 2.4 mile route everyday and it'll show .9 or some other number due to the GPS failing on and off. Oddly, when I first purchashed it. it worked flawlessly. This issue started a month, maybe 6 weeks ago.
GPS works again. The last app version 2.8 fixed it and now it works great.
Ohh really did it work for you .. i will try 2.8 and will let you know ,,,, thanks for the info @SunsetRunner
