03-28-2021
05:48
20:47
03-28-2021
05:48
20:47
My versa died & I bought a versa 3. I can't find my old clock face. Is there a way to go back and see old clock face names ? I really liked it because it showed my hourly steps. It was a cancer clock face with an orange heart. Thanks
03-28-2021 06:12 - edited 03-28-2021 06:13
Hi @cherylmurphy - I searched clock faces for “hourly steps” And found these.
- Stacked
- CD Breathe
- Control Panel
- Colourboard
- Tiler
And more. None show a cancer face. Or an orange heart. But you can look thru them and see what you like. Some of these clock faces require a nominal fee. To search, as I did:
There are quite a few there! Let us know which you choose.
03-28-2021 07:00
03-28-2021 07:00
@cherylmurphy The Versa 3's screen isn't the same size as the earlier Versa series watches. There are few, if any, early Versa series clock faces that can be installed on the Versa 3, especially if it is a third party clock face. I'm confident your old clock face isn't available for your Versa 3. Your best bet is to follow @SunsetRunner 's excellent advice and find a new clock face.
Laurie | Maryland
07-18-2022 14:05
07-18-2022 14:05
Those instructions don't work for me. I have a Sense with FitBit app on Andriod. When I click the magnifying glass, I just get a list of categories.
07-18-2022 18:18
07-18-2022 18:18
Hi @jkelley100 - if you want to find clock faces, or change them, in the Fitbit App, pull down and click on battery on the status bar at the top, then Gallery tile, then search icon (top right), enter the search criteria up top.
You can also click on the Clocks tabat the top to see categories.
