Where do I find more clock faces for my Versa 3?
i try to find more watch faces , than the store please advise
5 REPLIES 5
Hi @mahmoud_kham -  in the Fitbit App, pull down the Today screen to sync, immediately click on battery [top right], then click Gallery, then on the Clocks tab at the top.
You can enter the search criteria or browse by the sections listed - view all.
Hi there, @mahmoud_kham. Thanks for stopping by in the Community Forums.
Fitbit devices offer various designs for your clock screen in the Fitbit App Gallery. For more information, see How do I change the clock face on my Fitbit device?
See you around.
hello dear
yes i know the above mentioned method but i search watch face out of fitbit gallery which in app
hello there @MarreFitbit
yes i know this method for watch face gallery in apps isearch for other sources or website as i mentioned above i search than the store
so i now the store method
@mahmoud_kham - you will only find clock faces in the Gallery.
This is because you can only load them from there unless you write your own, or someone shares a private link.
That said, you can use Google to search the gallery as you can enter better search criteria for getting what you need.
