01-03-2019 09:48
01-03-2019 09:48
I'm liking the ability to now add my weight right into my watch instead of the phone app. But where does that data go to? It isn't showing up in the weight section of my phone app or on the Fitbit site.
01-03-2019 10:07
01-03-2019 10:07
Hi, assuming you are logged in into your fitbit account, go to https://www.fitbit.com/ on your PC/Laptop and you will see Fitbit's Dasboard appearing. On top of the screen on the right side, you will see the settings icon, press that and choose settings. You will see the page with your Personal Info. Scroll down untill you see "Weight" and enter the value. Scroll down to the bottom of this page and press "Submit". You're all done now. Good luck.
01-03-2019 15:59
01-03-2019 15:59
Thank you. I know I can enter my weight on the website, and I can log it in the app. As of the new firmware update for the Versa you can enter your weight directly in the Versa as well. However, the info I put into the watch doesn't appear on the app, or the site.
I was hoping to be able to track weight changes from day to day directly on the watch.
01-03-2019 16:06
01-03-2019 16:06
Hi, unfortunatey this is not possible. You can see your weight in the New Today screen, but not alter it on the Versa itself. You will still need to go to your Fibit's Dashboard every day and enter your weight manually. Press on the Fitbit's Dashboard the weight icon and press it and it will ask you to enter your new weight form the current day. Sorry that I cannot make this easier for you. good luck.
01-03-2019 16:11
01-03-2019 16:11
Thought it was just me.
It would be silly if the versa has an option to input on the watch, but the data doesnt sync.
01-03-2019 16:14 - edited 01-03-2019 16:19
What do you mean by the data will not sync? Once you filled in your weight on Fitbit's Dasboard and synced it with your Versa, the weight will be displayed in the Today screen when you have activated that. Swipe up form the bottom of your Versa's screen and you will get the Today screen, if you do not have activated weight, scroll down untill you see "Settings" and press that. After that scroll down untill you see Weight and click on it to activate it and you're done!
01-03-2019 16:26
01-03-2019 16:26
01-03-2019 16:29
01-03-2019 16:29
Data input via the phone can be seen on the versa.
Data input via the versa cant be seen on the phone app.
Defeats the purpose of giving us the option in this new update.
01-03-2019 16:36
01-03-2019 16:36
No. it's not a bug at all. The Today screen is relying on the information it gets from your Fitbit app. So, if you want your weight to be displayed in the Today screen, enter in manually by tapping the Weight in the Fitbit's app and press "Enter weight" (in the middle of the screen on the left side) and add it manually. After having doing that, press on top of the screen "Save" and your weight will be saved. Sync after that with your Versa and in the Today screen, when it's activated, you will see your weight.
01-03-2019 16:38
01-03-2019 16:38
The Versa by itself has no keyboardto enter your weight value, only for entering the pincode for the use of the Wallet app!!!
01-03-2019 16:43 - edited 01-03-2019 16:44
Have you even tried the function before replying to the posts ?
There is an option to key in via the versa, and it states the time it is logged.
01-03-2019 17:10 - edited 01-03-2019 17:37
Sorry, you're right about that. My sincere apologies are necessary now You have to be honest to admit when you make a mistake, as in this case! On the other side, though, WiredWeird is right with his post that you can enter your weight on the Versa, but will not show up all the time after syncing with your Fitbit App. Tried it myself but no update within my Fitbit app. So all in all, it's still better to enter your weight into the Fitbit app and sync it with your Versa than vice versa.
01-11-2019 10:29
01-11-2019 10:29
My new Versa has function to ad weight on watch, but it's calculations are dubious and does not seem in touch with AP on phone.
01-11-2019 10:30
01-11-2019 10:30
Not working on mine.
01-11-2019 10:32
01-11-2019 10:32
True, but why the entry function on the watch?
01-15-2019 11:18
01-15-2019 11:18
Have you tried entering a weight without using the decimal digit? Do you have a "point" or a "comma" on your display?
https://en.wikipedia.org/wiki/Decimal_separator
There is a bug. When you try to enter the weight with a comma it won't be saved.
12-12-2019 12:42
12-12-2019 12:42
Hi. Okay, so I enter the correct weight in the app, and it tells me I have 8 pounds to lose, which is correct. But what I see on the watch screen is 184 pounds left to lose. Even when i synch, it doesn't change. Sorry. I'm confused.
12-14-2019 09:41
12-14-2019 09:41
Me again. I found the cause of the issue. My Fitbit, when it works, is tied to my Weight Watchers app, and that has an erroneous weight entry from who knows where. It could have been a manual entry I made in error. Not a Fitbit problem.
