04-18-2018
15:11
19:57
EdsonFitbit
04-18-2018
15:11
19:57
EdsonFitbit
Does anyone know where to purchase a screen protector for the Versa? Anyone have any suggestions on the best screen protectors to buy? TY
Moderator edit: added label
04-18-2018 15:15
04-18-2018 15:15
Got mine from Amazon and I love it. No air bubbles and you can’t see it on. Comes with 6 in a pack for like $8.
Best Answer04-18-2018 15:17
04-18-2018 15:17
what are they called? and they fit the versa well? I hear a lot of them that get sent out are too small for it.
04-18-2018 15:21 - edited 04-18-2018 15:22
ordered mine from amazon
all the ones I looked at were not in stock so I have to be careful until April 30th
Best Answer04-18-2018 15:23
04-18-2018 15:23
I used the iq shield. Worked great.
Best Answer04-18-2018 15:24
04-18-2018 15:24
@dmilly83 I bought mine on Amazon. I bought this one and was deciding between that and this one. They're both pretty good I just didn't like how I had to make my own solution for the Ace screen protector. It's okay, it scratches easily but it heals really fast too. I was cleaning my screen with my shirt and nails and I was not pressing down hard at all and it created 'scratches' or it might because I didn't put it on right. But anyways you can only see it when it's tilted at an angle and if you're specifically looking for it and even then the self-healing is really good they are almost gone!
Want Spotify for Versa? Click Here to Vote!
Click Here to Vote for Low Power Mode!
Best Answer04-18-2018 15:25
04-18-2018 15:25
I got the EloBeth 6 pack. I think they fit the face quite well. They reach all the way to the curve part of the screen. I also bought a case protector for the edges too lol.
Best Answer04-18-2018 15:26
04-18-2018 15:26
@Bobled I'm using that one too, is it just mine or do you find it easily scratched? If you don't mind trying, can you gently-like super gently-run your nail over the screen? My nails are super dull-actually I cut them-and they still leave a scratch. Thanks.
