03-05-2020 10:47 - edited 03-23-2020 08:08
Finding a compatible set of Bluetooth headphones for my Versa has been an incredibly time consuming, costly and frustrating experience. So I propose that we post our failures and successes in this thread to help others choose a suitable set of headphones. I'll begin:
Versa OG - Apple AirPods Pro
+ Pairs and reconnects fine
+ Track skip works
- No volume control
- Volume stuck at low/moderate level
Versa OG - i500 TWS Arie2
+ Track skip works
- No volume control
- Volume stuck at max/distorted level (not recommended)
Versa OG - Langsdom L33
+ Pairs
- Audio is extremely choppy and unlistenable (I've tried a second pair with no more success)
Versa OG - Creative Sound Blaster Jam
+ Track skip works
+ Volume control works
Versa OG - JBL Tune 220TWS
- Paired once (and all controls worked fine) but since have been unable to pair again, even after factory reset of JBL device
+ EDIT March 2020: After doing a full factory reset of my Versa, I was able to pair my the JBL Tune 220TWS again and it is working as expected with very occasional audio dropout. This is quite a good alternative to the Apple AirPods as the Versa's volume control can be used, and the buttons on the earbuds can be used to skip track or play/pause.
The above results were all for the original Versa with firmware 32.70.7.14.
Best Answer03-12-2020 13:48
03-12-2020 13:48
@PatTheDog It's nice to see you on the Community. Sorry for the delayed reply.
I appreciate the time you took to share your experience with Bluetooth headphones and Versa. I'm sure this will help others in the forums.
Hope other users can join and share their experience with other heaphones!
