10-08-2018 12:57
10-08-2018 12:57
I'm researching a new Fitbit and would like to know which Fitbit records steps when you are holding a shopping cart handle. The HR I have now does not record steps if my arm is not moving. I'm assuming this one works on a pendulum concept. Please help!! Thank you in advance.
Best Answer10-09-2018 01:03
10-09-2018 01:03
All fitbits track steps by detecting movement of the tracker and then working out whether that movement was the result of a step or just random movement.
For all wrist-worn fitbits this means it depends on the movement of your arm / wrist and when you are holding onto a cart / trolley your movement is not the normal movement it expects to see from stepping so it can often miss steps.
The only fitbit that avoids this issue is the Zip which is clipped to your clothing rather than worn on the wrist. There used to be the fitbit One as well which also clipped to clothing but this is no longer available.
10-09-2018 01:03
10-09-2018 01:03
