05-16-2018 20:12
05-16-2018 20:12
My Versa battery running down in in 5 to 6 hours?
05-16-2018 19:46
05-16-2018 19:46
Why is my Versa battery running down in 5 to 6 hours?
05-16-2018 20:30
05-16-2018 20:30
How can I Improve my Fitbit battery life?
http://help.fitbit.com/articles/en_US/Help_article/2004/?q=improve+the+battery&l=en_US&fs=Search&pn=...
All of the below will drain the battery
In your app make sure:
All day sync is not on if it is turn it OFF
Turn off quick view
Do you get a lot of Notification as well?
Wendy | CA | Moto G6 Android
05-16-2018 21:03 - edited 05-16-2018 21:05
@Dorthlee65 if @WendyB suggestions dont significantly improve the battery I think you should contact Support or return it to the store you bought it for an exchange. Battery should last a lot longer than that.
Just another thought - what clockface are you using? Some use up a lot more power than others. You should be pretty safe with any of the fitbit ones I think.
Helen | Western Australia
