Why do I have to enable location to sync?
I've had my Versa now for a couple of days. It is obviously syncing because, each time I look at the app on my Android phone, the grey bar moves from left to right and my stats are updated. However, just below the grey bar there is a warning: Enable Location to Sync. Is there a reason for this warning? If there is, could it be reworded to be more accurate? Thanks, Warren
2 REPLIES 2
It's great to see you around @DoctorWkt.
Regarding your inquiry about why you have to enable your location in order to sync, I recommend taking a look at the Why is the Fitbit app prompting me to turn on location services? article.
I hope this helps, let me know if you need anything else. Woman Happy
So the article states: "Google changed its permission requirements beginning with Android OS 6.0 (Marshmallow). As a result the locations permission is necessary to sync your tracker with your Android device."
I've been informed by Samsung Gear S3 owners that they do not require their GPS to be on to receive notifications? Additionally, the article states the permission is necessary to sync and not enabled; although another states it must be enabled (https://stackoverflow.com/questions/33045581/location-needs-to-be-enabled-for-bluetooth-low-energy-s...). Thank you for any further clarification.
