Why heart rate zones on Fitbit devices are lower than general standard?
Hi
Does anyone know why the heart rates zones on the Fitbit are lower than the general standard everywhere else? E.g. the fat burning zone on Fitbit is set from 50% of your max heart rate, whereas everywhere else sets it at about 70% of your max hr??
Kat
2 REPLIES 2
1)  As for other places using 70% max heart rate as start of fat-burn zone, I suspect you are thinking of arobic zone starting at 70% of max heart rate, rather than fat-burn zone.
However, Fitbit does not use that anymore anyway.
2)  Fitbit's % of max heart rate was dropped a few years ago and is now used only on a few of the older devices.  The Versa 3 uses a more complicated formula that takes into account your resting heart rate.
What you referred to as the "general standard" is actually a less accurate simplified version that doles not take into account one's resting heart rate.
@Kat610 Fitbit zones are jusy it - Fitbit zones. There is no equivalent of that anywhere else. Other platforms use rather established models like Coggan's 5-zone model. The Fat Burn zone is also rather Fitbit's idea and at best may be compared to recovery/low-aerobic zones of other HR zone models (well... not exactly). As @JohnnyRow already mentioned, newer devices use different formula to calculate zones as they use Heart Rate Reserve rather than MaxHR. HRR is MaxHR - RHR. In general, the formula is (HRR x Z%) + RHR. The Fat Burn Zone starts at 40% of HRR. My HRR is 150bpm (max 192 and RHR is 42) so this gives 40% of HRR = 60 and add RHR, which results in 102bpm. This is where my FB zone starts. This is roughly 53% of MaxHR. It's way below my warm up/recovery zones in other HR zone models though (Coggan's model's warm-up/recovery using LTHR% starts at 115bpm for me).
EDIT: I just realized the calculation above uses artificially inflated MaxHR (I don't use 220 - age, I have different way of setting up my zones and use custom MaxHR). But if I used 220bpm-43yo that would set my MaxHR to 177 and HRR to 135. Then my FatBurn would start at 96bpm.
I have a theory that Fitbit just set a lower band for zones so it is easier for users to achieve zone minutes or simply to get a credit for lower intensity activity (users don't like to see Below Zones) and since Fitbit isn't made as a training device it is a possibility that the company wanted to make a Fat Burn zone a low hanging fruit. See that majority of users are not athletes and many mostly walk.
