10-16-2019 05:53
10-16-2019 05:53
10-16-2019 11:36
10-16-2019 11:36
Try turning your bt setting on the versa to on. Pair is only used so that the phone can find the Versa Classic during the initial pairing of the BT device.
10-16-2019 11:52
10-16-2019 11:52
Thank you,but that don't work wish it was that simple. thanks again for ur help.
Best Answer10-16-2019 11:58
10-16-2019 11:58
The versa BT will switch from pair to on if their is a phone connected. Without a connected phone the BT should switch off.
May i ask what the issue is and the type of phone?
10-16-2019 12:07
10-16-2019 12:07
Galaxy s9 n my heart rate monitur works but it doesn't say its connected in my bt menu, and i finally figured out how to contact fitbit n there just sending me a new 1 thankfully. but thank you 4 the caring hardest thing is waiting now.i hope nothing is wrong with the new 1 you no.
