04-17-2018
12:56
10:00
RobertoME
04-17-2018
12:56
10:00
RobertoME
Is the Wifi supposed to stay connected if I am in my home where I connected it at or does it disconnect after a certain amount of time?
Obviously it will disconnect after I leave my house, but will it reconnect automatically when I come back into my house?
Mine does not appear to be staying connected and I am having sync issues (just restarted my Versa) so will see if that helps, but not sure what to look for on the Wifi issue.
Thank you.
Moderator Edit: Updated Subject For Clarity.
11-26-2018 15:51
11-26-2018 15:51
What is the timeline for Wi-Fi to be enabled, or is all the marketing a blatant deception?
It's not a hardware limitation. It would have to be FitBit disabling the transmission of a few MBs per day, but allowing GBs of audio. That just makes no sense at all
If Wi-Fi isn't available for the core functionality of the device, it should be stricken from the product description entirely
Regarding the syncing issues you have mentioned, note that your information won't sync using the WiFi network you have configured on your tracker.
04-18-2018 10:09
04-18-2018 10:09
Hello @Toochi, nice to see you again in the Fitbit Community! I saw you are having some questions regarding the WiFi settings configured in your Fitbit Versa.
According to our help article: How do I connect my Fitbit watch to Wi-Fi?, It automatically connects to an available Wi-Fi network when plugged into the charger.
Regarding the syncing issues you have mentioned, note that your information won't sync using the WiFi network you have configured on your tracker. This works to download playlists and apps from the Fitbit App Gallery, and for faster firmware updates. For syncing issues, I recommend the following steps: Having trouble syncing? (here's how to fix this)
See you around and hope this helps.
06-14-2018 19:57
06-14-2018 19:57
I am having the same problem. Mine connects to the wifi but when I leave the house and come back i have to reconnect to the wifi. Any suggestions?
07-04-2018 18:08
07-04-2018 18:08
I'm having the same issue except it requires me to re-enter my password in the app Everytime my phone goes to sleep. It's impossible to get my Pandora playlists to download 😞
07-04-2018 18:52
07-04-2018 18:52
As far as I know the Versa will only connect to WiFi when it's needed. That will be for transferring music to your device, faster app downloads from the app gallery and for faster OS updates. Also note that Wi-Fi won’t work on your watch when the battery level is below approximately 25%.
From what you are saying it would appear that your Versa is behaving normally regarding WiFi.
As for your syncing issues the Versa will only sync via Bluetooth, WiFi isn't used for syncing purposes. You may wish to check out the help article why won't my fitbit device sync?, follow the troubleshooting steps and see if that solves your sync issue.
07-04-2018 18:59
07-04-2018 18:59
Sameness with me I don’t know what’s the deal with that but keep trying
07-16-2018 17:20
07-16-2018 17:20
Went to link, turned power saving mode off and all my emails came as notifications on fitbit versa now ready to try downloading music
08-19-2018 13:20
08-19-2018 13:20
I have a new Versa, handed over my charge 2 to hubby. First couple of days was fine but now less than a week later my Fitbit will not connect to WiFi at all, comes up saying “cannot locate device try again”. Nada. It will not keep steps, stairs, sleep (the basics) updated at all. I am ready to return to Fitbit and take back my charge 2. Very unhappy !
08-19-2018 20:08
08-19-2018 20:08
09-02-2018 02:47
09-02-2018 02:47
Versa seems to have problems with reconnecting. It has happened multiple times during the two months my wife has used it. The tracker also starts to lag, a press of a button takes several seconds before the display is reacting. Restart of the tracker is needed.
09-02-2018 06:37 - edited 09-02-2018 06:42
Thanks. I did try restarting/booting my tracker and that ended up working. It has done the same thing once more. Very annoying but at least I know what to do now
09-02-2018 06:38
09-02-2018 06:38
Thanks. I did try restarting/booting my tracker and that ended up working. It has done the same thing once more. Very annoying but at least I know what to do now.
11-26-2018 15:51
11-26-2018 15:51
11-26-2018 21:04
11-26-2018 21:04
01-08-2019 21:43
01-08-2019 21:43
You did not answer the question?
please tell me in common english
why won’t my versa stay connected to the internet. It goes offline in about a minute. Every time I have to re enter the password. Again in my plain English explain
01-08-2019 23:22 - edited 01-08-2019 23:34
@Jimd72 wrote:Answer my question
why wont my versa stay connected to the internet? Just answer this in plain English.
i do not need to know to connect it I want to know why it won’t stay connected?
Quite simply, to save power.
Its not necessary to enter the password each time and manually connect. Your Versa will automatically use WiFi if and when it's needed, which will be when you put it on charge (to update apps), or for the transfer of music to your device.
For what reason are you insisting on permanently staying connected to WiFi? The battery life would be awful.
01-08-2019 23:27
01-08-2019 23:27
01-08-2019 23:29
01-08-2019 23:29
No
it does not connect on charger
it cuts off wi fi every 20 seconds
i have to read enter password because it has to be entered to re connect again it does not connect on charget
01-08-2019 23:33
01-08-2019 23:33
Are you trying to transfer music to the device?
01-08-2019 23:34
01-08-2019 23:34
This is the third time trying to send this reply I keep getting a bunch of error messages
it drops wi fi after 20 seconds and won’t connect until I enter password again every 20 seconds
wont show my sleep patterns either but that another problem
not anywhere on your web site or book or questions does it say that the watch goes offline every 20 seconds
