12-14-2022
10:49
16:57
12-14-2022
10:49
16:57
I've already tried connecting it several times, while it was charging, when charged full, with low battery, but both 2,4G and 5G are marked as out of reach, although I'm no more than 2m away from the router. Is this some kind of error or fixable?
12-15-2022
02:12
08:42
12-15-2022
02:12
08:42
Hi @CyanNide - it will only work on 2.4Ghz, but the watch could have a fault.
First sync the watch and do a Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on charge to restart it and charge it, or push the button. Then try again.
You can work without WiFi. If your watch is working fine with Bluetooth, unless you need especially it for something best to leave it like that.
If a restart does not fix it and you really need it try chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support. They can take you through a factory reset or replace the watch.
It will have to be setup all over again and if the WiFi doesn't work still it will have to be done over Bluetooth which can take an hour or so.
Replacing the watch means you can be without it for a while and have lots of setting up to do, so make sure you really need WiFi.
12-15-2022
02:12
08:42
12-15-2022
02:12
08:42
12-15-2022 03:02
12-15-2022 03:02
Thanks for your answer. To be honest, I gave up trying. I was using it without WiFi for two months and everything was just fine, so I guess I'll just leave it like that before I mess something up
02-11-2023 19:47
02-11-2023 19:47
Thank you! I’d nearly lost hope and then came across your answer! It worked like a charm! 🙌🏻
I’m getting a new FitBit through my insurance company (I guess they think it’ll keep us moving) but want to be sure this one is working before I pass it on to a friend.
Thanks for the help!
