12-10-2018 05:26
12-10-2018 05:26
How do I get the WiFi turned back in my Versa? It is saying it is off on my wrist band and I have tried everything and it keeps saying it’s looking for WiFi connection on my app... can anyone help me please?
 Best Answer12-10-2018 06:30
12-10-2018 06:30
Hi, on the dashboard, press the icon of the Versa. It brings you to the page showing clock faces, etc. Scroll down untill you see Wifi setings. Press that and look if it shows a network. If yes, press the network and manually add the password of the network. If not, press Add a new network and manually enter all the needed information. Hope this helps.
 Best Answer12-10-2018 14:46
12-10-2018 14:46
 Best Answer12-10-2018 15:21 - edited 12-10-2018 15:50
Hi, another possibility is, whenever your network is on your mobile device, to remove it. Restart your router and try it again, e.g. adding network and filling in all the information about your network manually. After removing the network from your device, restart it before trying again. Good luck.
BTW, if no network is displayed on your mobile device, restart your mobile device and your router and then got to adding new network and fill in everything needed manually.
BTW 2: mind you that the password for your network is Capital sensitive!
 Best Answer12-12-2018 03:38
12-12-2018 03:38
