12-29-2018 16:09
12-29-2018 16:09
I have done all the help topics at least 5 times and it will not connect. My phone connects to wifi just fine. I have restarted Fitbit and my phone. I have disconnected and reconnected my Fitbit to my phone. I have deleted the Fitbit app. Nothing works
12-29-2018 21:57
12-29-2018 21:57
12-29-2018 16:30
12-29-2018 16:30
Hi, in order to get your WiFi up and running, do the following:
See this:
The Versa will only connect to WiFi when it's in the charger and connected to a PC, As the Versa does not have WiFi on its own, it uses the WiFi of your Phone or PC as a bridge. Whenever you have done this, go to your device's Fitbit app and to WiFi settings. Do you see your Network now? If yes, press on it and enter manually the password of your router, mind you it's Capital sensitive. Once you have done that, there should appear on the right side of your network's name a white icon. Press that and Fitbit starts connecting to your network. Whenever this succeeded, the white icon will turn to blue and it will say "connected". At this time your Versa is also connected to WiFi, but only, as stated above, as long as it's in the charger and connected to your PC. If no network is present, press add network, enter the name of your router and password manually (again Capital sensitive) and it will be added as your network. For the rest it's the same as if your network was already present, e.g. white icon, etc.
12-29-2018 21:57
12-29-2018 21:57
01-03-2019 18:54
01-03-2019 18:54
Had to update via Bluetooth, wifi never connected
01-21-2019 10:41 - edited 01-21-2019 10:54
Kuzibri......So whenever we want to utilize wifi, we need to put it back in the charger?
01-21-2019 11:00
01-21-2019 11:00
Unfortunately yes.
01-21-2019 11:02
01-21-2019 11:02
Hi, unfortunately yes, the Versa needs to be in the charger. See my earlier post in this topic..
