01-17-2020 02:38
01-17-2020 02:38
Hi,
I recently purchased a Fitbit Versa 2.
I have noticed that the Stairs counting is activated when using a Elliptical Machine at the Gym.
I turned up at the Gym the other day and checked my Stair count prior to using the Elliptical Machine. It read 8 which was approximately correct for the number of Stairs ascended. I started using the Elliptical for approximately 30 minutes and on monitoring the Stairs counter on my Fitbit I noticed that the Stair count was slowly rising. After the 30 minute Elliptical session the Stairs count indicated that I had ascended 43 flights of Stairs which was an increase of 35 Stairs when in fact I had never left ground level during this period. I have read other posts reported this problem and can advise that I was not near a fan or in any areas where the air pressure was changing. Overall this inaccuracy is not acceptable for this very pricey Watch. The reason I ordered this item was to accurately check my daily activities.
01-17-2020 03:07
01-17-2020 03:07
The stair counting is activated while steps are being counted.
Best Answer01-17-2020 11:00
01-17-2020 11:00
01-19-2020 18:06
01-19-2020 18:06
Exactly @Gazza1954 but then any decrease in air pressure while the tracker is counting steps may produce a false floor count.
