04-21-2018 10:06 - edited 04-21-2018 10:07
I currently have a Blaze and a few accessory bands that I really like. Will these bands work on the Versa? I don't want to have to buy all new bands if I decide to upgrade to the Versa.
11-24-2018 07:18
11-24-2018 07:18
I just ordered those bands. There are so many colors and they look really nice.
12-16-2018
07:02
15:14
12-16-2018
07:02
15:14
@starladypdx @emz8082 @TP23 Welcome! It's great to see you around! Sorry for the late reply.
@starladypdx thank you for sharing your experience with us and happy to hear that your Blaze band fit onto your Versa. Could you share some pictures?
@emz8082 Thank you for your feedback. Based on your post I guess you are using Versa bands on a Fitbit Blaze. I can see this as feasible as Versa bands are smaller than Blaze ones. The question here was if you could use the larger Blaze bands on a Versa.
@TP23 how did it go with the bands you purchased? Did they fit your Versa? Could share some pictures of the bands you purchased?
I look forward to your replies!
12-27-2018 09:04
12-27-2018 09:04
Would like to know if the house charger from the blaze will fit the versa
12-27-2018 09:05
12-27-2018 09:05
@Cindy1350 The charger will definitely not work. Fitbit likes to require its customers to buy all new accessories for each model.
02-19-2019 12:59
02-19-2019 12:59
I will stick with my Blaze until it dies then. Fitbit, you would have had a sale but since using the Blaze charging stands I've got, I'll skip this "upgrade" and wait for the next one, or two, or three.
04-25-2019 05:06
04-25-2019 05:06
Good luck with the Blaze working more than 1 1/2 years.
My research and experience has showed me that if you get more then that you are lucky. I have blaze chargers that it would be nice to used but I am not going to buy a new watch ever year just to used the charger.
04-25-2019 05:49
04-25-2019 05:49
My Blaze heart rate tracker stopped working after I got my Versa. I like the Versa much better than the Blaze.
09-03-2019 01:09
09-03-2019 01:09
No it will not work it would come with a band
09-03-2019 01:12
09-03-2019 01:12
No that can't be done
09-03-2019 01:13
09-03-2019 01:13
There is only 2 colors for the versa
09-03-2019 01:14
09-03-2019 01:14
There is some that are xl keep looking
09-03-2019 01:16
09-03-2019 01:16
No the blase and versa aren't compatable sorry
09-03-2019 01:18
09-03-2019 01:18
No thy won't my of tried
10-29-2019 17:16
10-29-2019 17:16
That’s awesome! Were you able to just pop it on because they both use the same pin system? Or was there some special trick?
Currently having a hard time finding a black Versa band that has rose gold metal pieces instead of the silver that won’t match my new rose gold Versa
10-29-2019 19:06
10-29-2019 19:06
10-29-2019 19:36
10-29-2019 19:36
I was looking on Amazon and I couldn’t find rose gold hardware but I’ll try the other one. Thanks for the advice!
11-09-2019 08:45
11-09-2019 08:45
That’s so wrong all the bands, frames, should be interchangeable I can’t believe it darn darn darn I have a blaze doesn’t work so I bought a Vera pebble but have frames in every color for the blaze uuuggg!
04-21-2020 08:24
04-21-2020 08:24
I have a blaze now but want to buy a band that's for a Versa ... will my blaze fit ?
05-08-2020 09:23
05-08-2020 09:23
I had the Blaze before, and I had bought the camel leather watch band and the stainless steel link band. I was able to use the leather watch band on the Versa 2 I got, but I could NOT get the stainless steel link band to work, sadly. I think that the leather had a little "give" so I could squish it in, but the stainless steel band had no give, and was just the tiniest hair too wide for the Versa. I was so disappointed! I am going to buy the stainless steel link band now for my Versa 2; I like it because it makes the Fitbit look a little dressier & more professional for work.
08-07-2020 23:34
08-07-2020 23:34
I just bought a Versa2 and my Blaze bands fit just fine. I was told they didn't fit but they actually do. Since Versa 1 bands are interchangeable with Versa 2 they should fit.
