03-20-2018 08:40
03-20-2018 08:40
Does anyone know if the Versa will have the ability to set a vibrate alarm that will go off when you're in a light sleep phase (either within FitBit OS or external app)?
I'm currently using Sleep as Android with Pebble, to wake me with a gradually vibrating alarm when I'm in the lightest phase a light sleep, and would love to keep that feature if I upgrade to the Versa.
Thanks!
03-20-2018 08:49
03-20-2018 08:49
There's nothing in the versa manual that suggests the alarm feature is any different from other fitbit so I think it's safe to assume it won't have this feature (at least initially)
https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
03-20-2018 08:48
03-20-2018 08:48
I don't think it will have. The Ionic which uses the same OS (fitbit OS 2.0) doesn't have this feature, so I highly doubt the Versa will either.
03-20-2018 08:49
03-20-2018 08:49
03-20-2018 08:50
03-20-2018 08:50
@N8teGee you must type faster than me!
03-20-2018 08:59
03-20-2018 08:59
I'm really hoping it is something they'll consider adding in the future. Thanks! 🙂
03-20-2018 09:17
03-20-2018 09:17
