Will my versa 2 still work with Alexa now that google owns fit bit
Google has ok google , how will the alexa voice command still work when Alexa is through Amazon? Hope I didn't spend $200 for nothing
2 REPLIES 2
Hi @Hamch1994 , it depends on the country were you're living if Alexa is working or not. Visit this site to see if your country is listed in the supported ones. click the link and scroll down to the bottom of the page. Furthermore, when Alexa is supported, you will see a tile of Alexa within the Fitbit app on the page that aslo displays the Clock and App tiles.  regards kuzibri
Yes it will. The merger has not been approved yet, and may not be. When the merger is approved it will probably be at least a year before they fully integrate products and software. The Versa 3 will most likely have google assistant installed.
