Will the Fitbit Versa 2 work on my note 8?
Hi there! I was just wondering if the Fitbit Versa 2 would work on my note 8
Moderator edit: format
4 REPLIES 4
First place to check is here @Bryce_B
Second would be to search the forums, especially the Android forum.
Your really asking if the Fitbit app works on your phone
YES!!! i have a Note 8 and works great (before the latest versa update anyway)
edit..i see you're referring the Versa2...i have the 1. sorry. still should work though since hte app basically links them
Cool thanks for the tip!
Thanks I am going to buy one now 👍
