07-24-2018
07:36
05:07
MarcoGFitbit
07-24-2018
07:36
05:07
MarcoGFitbit
I have a pair of jvc wireless headphones that will not connect with my Versa it works with my phone but keeps on saying no devices found on my versa help and I do have it in pair mode
07-25-2018 05:10
07-25-2018 05:10
Hello @Adwright, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate you have brought this to my attention. Please note that the Fitbit Versa should be able to connect with your wireless headphones. If your wireless headphones are not connecting to the Versa, please try the following:
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
07-25-2018 05:17
07-25-2018 05:17
I had the same problem, so I took it back to best buy, cause both versa and headphones were less then 24 hours old...it took them some time to fix the problem, they unpaired the headphones from my phone, reset versa , and then paired the versa to the headphones and said that they cannot be connected to two things, but that isn't what the headphone instructions say...good luck
12-01-2018 17:55
12-01-2018 17:55
I did everything said here and my JVC headphones won’t pair. I’ve taken them off my phone and turned my phone Bluetooth off while trying. It’s not the headphones
