05-11-2019 15:04
05-11-2019 15:04
I go through the bluetooth settings on the versa, connect my wireless headphones and they work just fine. I go to use them the next time they say device not found. I literally have to go into the bluetooth setting delete them from the list, rsync them and then they work again. Anyone have a solution for this? Idk if its the versa or the headphones.
05-12-2019 16:10
05-12-2019 16:10
Do you use your headphones with any other device? If so do you make sure the headphones are not connected to the other device?
Best Answer05-25-2019 12:33
05-25-2019 12:33
Yes, I use them with my phone once in a great while but always turn my phones bluetooth off when I'm done.
