04-08-2018
18:01
03:55
04-08-2018
18:01
03:55
@KymberlyD Hey, there!
Versa is compatible with Bluetooth headphones. To setup, you can go to the Settings app on Versa > Bluetooth >+ Audio Device. After you press this make sure your headphones are also in pairing mode so that Versa can connect with them. If you're having trouble completing these steps, let me know where you are getting stuck. I'll be around if you need more help!
Best AnswerSorry just seeing this. I never got it paired I'll try again tomorrow see if it works
