01-02-2021
06:03
06:10
JuanJoFitbit
01-02-2021
06:03
06:10
JuanJoFitbit
Woke up and within 10 mins my Versa 2 was showing 13k steps. 2nd time this has happened in 2 weeks. Ive restarted, deleted and reinstalled the app after the first time it happened. Not sure what is causing this.
01-11-2021 06:09
01-11-2021 06:09
Hi @Lybra975, it's great to see you in our Fitbit Community. Regarding the steps that your Versa showed, I appreciate the time spent trying to get the issue resolved before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
After this, set up your watch from scratch.
Finally, monitor your Versa 2 and see if it stops tracking steps while you are sleeping.
Keep me posted on the outcome.
