03-19-2020 11:10
03-19-2020 11:10
I woke up this morning and my screen was black. Thought it need charge. Put it on the charger and the app said it was fully charged. Wouldn’t turn on. Did a reset and some lines showed on the screen and then went black again. Did it several more times. Came back on for a few seconds and then faded away to black. I get the vibration and green light still. I also got a very distorted date once. It was working perfectly when I went to bed. Cannot figure out what is wrong. Is it over for my Versa?
03-19-2020 11:19
03-19-2020 11:19
This is exactly what’s happened to mine today, was completely fine.
03-19-2020 17:03
03-19-2020 17:03
Hi @Nbctchick @JessR94 Try a Factory Reset and see if that fixes it (you will need to set up again). If the problem isnt resolved you will need to contact Support - please bear in mind that support has longer than usual wait times due tonthe impact of the Coronavirus on Fitbit staffing.
BUTTON FACTORY RESET FOR VERSA 2 AND VERSA LITE
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
03-20-2020 20:46
03-20-2020 20:46
Crazy thing is that my Fitbit seems to still be tracking. The screen is just not working. Someone else posted on another thread that changing the clock face might work. I tried that and it worked for about 10 seconds and then slowly faded to a distorted image and then went black. Unfortunately, I have had this one for a little more than a year. Really don't want to buy a new watch. I feel like this happened after their latest update. I cannot figure out what could have caused this. I literally went to bed and woke up to this problem. Very frustrating.
