Woke up with steps on Versa
I woke up thus morning and had over 29,000 steps recorded for the day. Tried shutting down; not a fix. Any ideas?
6 REPLIES 6
Is it near a vibration source like a fan, computet cpu etc? As it can add false steps like that?
Community Council Member
Wendy | CA | Moto G6 Android
A warm welcome to the Community @Mayre and @WendyB thanks for stopping by.
I am sorry to hear that your Versa is registering extra information and as our friend here, I would also like to know if there was a fan o anything that may have been buzzing or vibrating on the same surface your Versa was placed on?
Hope to hear from you soon. Smiley Happy
Yes, it is near a fan. That makes total sense. Easy fix. Thanks for the replies.
Yes, I think that is the problem. Thank-you!
You are welcome @Mayre, I am glad to hear that this has been resolved. If you need anything else, do not hesitate to post it.
Keep the stepping up. Smiley Wink
My Versa was also near a fan as I took it off last night to give my skin a break.  Is there anyway to delete the 33k steps it recorded? I tried to add 'driving' for the activity duration per the options for fixing and that did not change anything.  Thank you!
