06-05-2025 16:54
06-05-2025 16:54
06-05-2025 18:51
06-05-2025 18:51
Hello there @Cfran1929, nice to see new faces around!
Thanks for sharing this situation with us. Let me share some extra steps with you to see if we can get you back on track!
Can you first confirm if you are using the original charging cable that came with the device? Also, make sure it doesn't have any damage on the charging contacts!
If everything looks about right, can you try changing the power source you are using to connect the cable? The best option is to use a UL-certified wall charger or your computer's USB port!
Best Answer06-06-2025 08:03
06-06-2025 08:03
06-06-2025 16:55
06-06-2025 16:55
@Cfran1929 I want to add one thing regarding the charging cord. There are many posts from other users who noticed that one of the pins got slightly pushed in. Look closely at the pins and make sure they all look the same, not pushed in. It might be the cord.
Laurie | Maryland
06-07-2025 06:46
06-07-2025 06:46
I have tried three different chargers and mine still won’t charge.
Best Answer06-07-2025 08:26
06-07-2025 08:26
06-07-2025 08:34
06-07-2025 08:34
Best Answer06-08-2025 22:30
06-08-2025 22:30
Hey everyone, nice to see you all around!
Thanks a lot for taking the time to share your thoughts. Before we move on, I'd like to start by making sure you have done every step suggested on this help site.
Please let me know if that helps!
06-10-2025 15:46
06-10-2025 15:46
Tried that, didn’t help.
