Wrist band difficult to remove and put on
ANSWERED
The little tab in the sleeve that goes around the wristband catches every time I take it off and put it on. Is there supposed to be an easy way to use this?
1 BEST ANSWER
Accepted Solutions
@ieb23 oh I see. The little loop has a notch that slides into one of the band's holes to secure band in place (so it doesn't come undone). You need to pry it out (lift the little loop a little) to slide the band out. If you dislike this kind of bands, you can pick up a classic band without such security features on Amazon. They carry a lot of decent bands.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
5 REPLIES 5
@ieb23 Perhaps I'm slow today 😛 but are you talking about changing the band itself? This video might help.
Thanks, but no, taking the band on and off my wrist.
Thanks 🙂.  Yeah, I just wondered if there was a workable way to attach and remove the band from one’s wrist.  That little tab catches the band every time you try to put it through the slide to attach to your wrist and then when you try to pull it out to take it off your wrist as well.   I’ve never had a wristband so problematic to attach and remove from my wrist. I’d be better off to cut that little tab off than waste money on another band to replace a poorly designed one.
@ieb23 No worries. 😄 I personally like the tab because when I'm windmilling my hands around me I tend to catch my band on things... That could lead to losing my Versa! I guess it's a matter of personal preference. 🙂 Please enjoy your tracker!
