07-13-2018 02:45
07-13-2018 02:45
Hi All
Is there any way to stop the buttons on the side pausing a workout when they are pressed?
I go to the gym 3 times a week and do a variety of stuff (HIIT and strength classes) and my wrist is forever pausing my workouts when I do push ups, burpees etc. so I have to start it again and my instructor yells at me a) for stopping and b) thinks I am just fiddling with my watch!
Ive even bought a velcro strap to try and secure it tighter so I dont have that issue but its still happening and its really annoying! Other than that I love it!
Thanks y'all
Catherine
07-13-2018 03:59
07-13-2018 03:59
Wear it on your other wrist. There's still a button there but it only cycles through your stats.
07-16-2018 06:56
07-16-2018 06:56
Same problem here!!! Need an option to disable the side function buttons, at least during exercise, but I’d be fine disabling them completely.
07-16-2018 08:42
07-16-2018 08:42
I got a clear protective cover from Amazon. Works like a charm. Only issue is when you have to charge the Versa, you have to take the strap off so it sits correctly in the charger
08-09-2018 10:49
08-09-2018 10:49
Same has been happening with me. So today before my workout, I took the watch off and turned it upside down so that it is on the same wrist and it worked well. This is a little bit of a hassle because it's not as easy to see my heartrate and such during the workout. I've decided to order a protective clear cover on Amazon for $8.99. Worth a shot.
08-09-2018 11:36
08-09-2018 11:36
02-08-2019 13:29
02-08-2019 13:29
Which one did U buy? I kickbox and it keeps pausing!!!
02-08-2019 13:34
02-08-2019 13:34
04-02-2019 18:32
04-02-2019 18:32
Has anyone used the SUPCASE watchband/protector? Does it prevent inadvertent pausing during workouts?
