04-15-2019 11:59
04-15-2019 11:59
So I'm not sure what to do. At work today my wristband pin that holds it into the watch snapped and is now stuck in the watch and I can no longer wear the watch. What can I do.
04-16-2019 07:29 - edited 04-16-2019 08:05
Hi, try a very little (smallest) needle which you normallu use to sew a button to a shirt and see if you're able to remove the pin with that. You can also try a little screwdriver with a magnetic point, to which normally screws are holded, to remove the little pin. Caution, stay away from the sensors.
04-16-2019 18:56
04-16-2019 18:56
