12-07-2023
15:47
08:52
LizzyFitbit
12-07-2023
15:47
08:52
LizzyFitbit
Watch band wouldn't connect to the watch so I tried a nModerator Edit: Clarified subjectew watch band I had. That didn't work the connection for the watch band was worn. I drilled the hole a little deeper, shortened a rivet, slid it in the hole, and reconnected the watch band. It worked great
12-07-2023 17:15
12-07-2023 17:15
@Themotivator , A warm welcome to the Community! Thank you for sharing your experience and your solution. Please keep an eye on the band as some of these homemade solutions, could cause that the band does not keep attached securely to the Versa 2.
12-08-2023 09:36
12-08-2023 09:36
I'm having the same issue with my Versa 2. What did you use to drill the hole deeper?
12-22-2023 04:39
12-22-2023 04:39
I used a drill bit same size as the rivet
