09-25-2022
05:35
17:09
09-25-2022
05:35
17:09
The size of the “pint” used in the app is The US size not the UK, which is confusing.
can we request the name of pint is changed to “pint US” and a new one is added “pint UK” with the volume of 568ml?
09-25-2022 18:42
09-26-2022 23:44 - edited 09-26-2022 23:47
Hi @Guy_
I’m using the food - calories section of the Fitbit app to log calorie intake (in this case for cider, larger, beer).
Here the app only app only lets you roll up to 500ml and then tops out so can’t get to a UK pint of 568ml. If you try to use litres or cl instead you have to use fractions instead of decimals so you still can’t enter 0.568L for example.
at first I didn’t even realise the “pint” being used in the app was American at 473mm 😳
