Wrong info about calorie burn in my 3rd party app- Hotworx
Got a negative 711 calories not burned after an intense sauna workout….something’s wrong…not sure if it’s watch, Fitbit app, Hotworx app….suggestions?
3 REPLIES 3
Hi @Mcbohn  you didn't mention which Fitbit you had, but they don't work well in extreme environments. Might be the heat and steam didn't help in getting all your stats. You can check the user manual of your device to see the specific environmental conditions under which it will and won't operate.
Stepping in the U.S.A. since September 2013. Android 14
Thank you! Versa 2 and I think you may be right!
Sent from my iPhone
Versa 2 user manual, page 66 - 113 degrees F and it doesn't operate. How hot is the sauna? It very well may be the culprit. Moved your post to the Other Versa area of the forums if anyone else has some suggestions.
