01-31-2022 03:51
01-31-2022 03:51
Hi
I had hoped i wouldn't be writing about my fitbit. i have had my fitbit versa since 8/1/2020
which i have had for 2 years. for the last couple of days i had some syncing issues with it which i could or had fixed the syncing issues that i had but last friday my fitbit had decided to factory reset itself which i was able to set it up again but today for the last 2 hours i have been trying to fix my fitbit because i had some syncing issues again but then i had decided to do a factory reset after i had tried everything but nothing had worked and after i had factory reset my fitbit i had tried to set it up again but it has not worked at all and i know it is not my fault and i my iPhone 11 will connect with everything else buy not my fitbit and I don't know what else i can do to fix it and i don't want another fitbit versa cos i don't think that will work. and i was wondering if there is anything that i can do to fix my fitbit.
Thanks
