08-16-2020
05:15
20:02
EstuardoFitbit
08-16-2020
05:15
20:02
EstuardoFitbit
Hi All,
I received my replacement Versa this week, I cannot add a new clock face to this device. I am connected to wifi, I received the Green check mark on the device. I am going to the "clocks" on my device, looking at free ones, I try to pick one, there is no select button. I have been disconnected from Fitbit chat support twice, so aggravated. Can anyone offer a solution? I am extremely disappointed that I cannot use the watch. I have a Samsung phone.
08-16-2020 05:26
08-16-2020 05:26
@Madre3 The most common reason you can't download a clock face is that your replacement Versa doesn't have the current firmware. This happens to many users. It's pretty common that there was a firmware update between the time your Versa was manufactured and when it was shipped to you. A firmware update usually shows up 24-48 hours after activation. That's how Fitbit manages this, so just be patient.
Laurie | Maryland
Best Answer08-16-2020 05:28
08-16-2020 05:28
The company gave me an option of free versa replacement or 50% off another device. Should have went with the 50% off.....
I tried all the Help forums, I really need to speak or chat with an agent.
I even tried Utube, 🙂
Best Answer08-16-2020 05:36
08-16-2020 05:36
Best Answer08-16-2020 05:37
08-16-2020 05:37
Hi,
Not sure that is the issue, but I will wait and try again in a day or two.
Best Answer08-16-2020 05:46
08-16-2020 05:46
Everything appears ok accept I cannot sync to clock faces, I chose a face and I just get the "spinning circle" on my phone. I am on wifi, I did reboot the fit bit, turned phone off and on, reconnected to wifi, etc..
I don't know....
Best Answer08-16-2020 07:03
08-16-2020 07:03
I reinstalled the app, lets hope this works!
