05-25-2018 00:45
05-25-2018 00:45
I am trying to change the clock on my versa it says go to dashboard and click on clock....I can't find anything in my dashboard to do with clocks at all??
Best Answer05-25-2018 02:18
05-25-2018 02:18
Hi, @SunsetRunner, it will be on your app rather than the web based dashboard.
On your app click on your Versa icon and on the next screen you will see "clock face" . Select that and you will see lots of options.
Be sure to sync once you have made any changes. The clock face won't change until you sync.
Best Answer05-25-2018 01:16
05-25-2018 01:16
Click on the gear upper right and fo to settings. From there you will see a lot you can do
Wendy | CA | Moto G6 Android
Best Answer05-25-2018 02:16
05-25-2018 02:16
As an extra little tip, if you're not choosing a Fitbit-created watch face then make sure to scroll down and read the descriptions as some third-party watch faces are paid-for** and just timed trials to begin with.
**The Knight Rider one is especially great if you're a child of the 80s! ![]()
05-25-2018 02:18
Best Answer05-25-2018 16:19
05-25-2018 16:19
thanks heaps, have it sorted now...
Best Answer05-25-2018 16:20
05-25-2018 16:20
thanks all sorted now..
